Is the space completely bound by "Room Bounding" elements? No gaps?
...or Sketch the Ceiling
It's more than likely that your walls don't extend up to the height of the ceiling. Check your wall heights, and ceiling placement heights
Try and create the ceiling at a lower level - say 500 mm and then move it up after. If that doesn't work then do as BarthBradley suggests - sketch it.
@Anonymous wrote:
yes it is bound i have no idea what is wrong?
Do all bounding walls exist in the Phase?
..you know, you can always post your file.
@Anonymous wrote:
i tried before a couple months ago to do a celing which intersects with
curtain wall and it went fine, dont know what is wrong this time
We're aware that you don't know what's going on. So post the file. We'll figure it out.
