Ceiling constrains reset
3 ANTWORTEN 3
Nachricht 1 von 4
grruta
258 Aufrufe, 3 Antworten
Good day,
when drafting a ceiling - be it automatic or per sketch - the constraints reset to the chosen level every time a single sketch is completed. I would rather refer to a level above when sketching than to chosen level.
Please fix the issue as soon as possible.
3 ANTWORTEN 3
Nachricht 2 von 4
benschilders
als Antwort auf: grruta
Maybe try to explain your problem a bit better ?
That way you might have the change that somebody can help you...
Don't know or this is a rant or a question
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Nachricht 3 von 4
grruta
Whenever you draw a ceiling - you can specify the level form which the ceiling is offset from.
You might know that is true for every element in Revit - however, when you draw a ceiling - the constraint is being reset to the same level you are drawing on.
It is more of a rant. I am trying to submit every error in basic functionality hoping that Autodesk will start addressing the issues.
Nachricht 4 von 4
Ceilings are Hosted to Levels.
Are you trying to sketch a Ceiling in relationship to a Ceiling that is on another Level?  If so, use View Underlay to show the reference Ceiling.
