Ceiling based family will never show in floor plan?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
marieHPAJL
429 Aufrufe, 5 Antworten
Am I right - a ceiling based family will never show in the corresponding floor plan?
Would that be a reason to make ceiling lights something other than ceiling based? Work-plane based, not hosted, or something?
5 ANTWORTEN 5
Nachricht 2 von 6
brian
als Antwort auf: marieHPAJL
Most people wouldn't want stuff on the ceiling to show up on the floor plans, try using a "Ceiling Plan".
Nachricht 3 von 6
filipefrancisco
Try to see in VIEW RANGE in the properties of the floor
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Nachricht 4 von 6
scott_d_davis
a ceiling plan and a floor plan can be overlaid on a sheet to show both at the same time.
Scott D Davis
Sr AEC Technical Specialist
Nachricht 5 von 6
Would an Underlay View work for you?
Nachricht 6 von 6
marieHPAJL
Yes, I do use underlays. I am not sure if my question makes sense anyway. Will look into it.
