I'm modelling a bulkhead, the ceiling plan and section look fine. When it comes to elevation the joint line between the wall and ceiling keeps showing. I could't resolve it. Anybody familiar with my problem? Thanks.
Try reversing Join Order, although this is not an uncommon phenom. If it's due to what I'm thinking, it will not translate onto the printed documentation.
Thanks for the note,
I tried doing that and its not working... also visible in print preview. I've to use line works to make the join-line invisible.
Did you use Join Geometry? Try to model the wall before the ceiling so you can use Pick Wall for the ceiling.
Make sure you are using the same material for the finish layer of the wall and the ceiling.
