Cavity separating wall clean up
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
cadmunkey
396 Aufrufe, 2 Antworten
Hi guys, I am a new Revit user having mainly used Sketchup for the past ten years. Anyway I purchased Revit LT recently and have been teaching myself the software using tutorials on Lynda. One thing I cant seem to find, either on the tutorials or google is the correct way to get some walls to 'clean up'. I am using Revit on a current live project in order to help me learn from the ground up. Its a small block of flats, the separating walls between flats are not allowed to span across the cavity. See attached pic, this shows how my walls are being cleaned up as they stand.
https://i.imgur.com/kIoF81G.png
I need them to clean as per this second pic, but I cannot figure out a way to do this at all. Any ideas to help a Revit noob please?
https://imgur.com/vRGOSon
2 ANTWORTEN 2
Nachricht 2 von 3
loboarch
als Antwort auf: cadmunkey
It has to do with the "function" you have assigned to the layers of the wall.  You need something like this so the function numbers of the layers align and will clean up the way you want them too.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 3
cadmunkey
als Antwort auf: loboarch
Thankyou very much loboarch, I think I have misunderstood these "functions", I was using the block wall as the "structure layer" as obviously to me that is the structural part of the wall. Once I changed the cavity concrete fill to the "structure" and the two leaves of block to "substrate" the wall performs exactly how I want it to. I think its going to take me a while to get used to how these "functions"  perform.
In the meantime thanks again, I think I may be posting again very soon!
