Cast-in-place stair - lineweight overrides
5 ANTWORTEN 5
Nachricht 1 von 6
cbt990
290 Aufrufe, 5 Antworten
Here's a weird one. I am trying to change the lineweight of this 2 riser cast-in-place monolithic stair. But it only seems to make the points at the vertices appear thicker:
Revit is amazing
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: cbt990
Nachricht 3 von 6
cbt990
Different stair - those are site-built standard steel stairs, not cast-in-place.
Revit is amazing
Nachricht 4 von 6
RDAOU
@cbt990
But that did fix the arrow issue no?
Anyhow...attach the stair if you wish and can have a closer look what is going on at your end...
Nachricht 5 von 6
Override element in view or Override with Linework tool?
Nachricht 6 von 6
This?
Got Treads?  Remove them or just continue using the Linework tool and select the "dots" next.
