Casework Lineweights
PhilvK
Advisor Advisor
PhilvK
How do you control the lineweight of casework elevations? I created one as a generic model, went into visibility graphics and changed the “lines” category to a wider line, but there was no change on the elevation.
cbcarch
Manage Tab>Object Styles>Casework>Projection Lines
or, do the same in a View Template which is applied to your elevation views.
However, Since you made the casework as a Generic Model-- if you change the Object Styles setting per the above for GM,
ALL Generic Models will change.
To do this, you could set up a Filter and override graphics in your elevations for ONLY the casework generic models. A bit tricky, but it is possible.
It would be easier and more "as intended" to change the GM to casework category.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
