Casework Labels Not Working
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
Ed_Cormier
1086 Aufrufe, 21 Antworten
I'm trying to add nested labels into casework families with work-plane based enabled. When loading into a project model group, we get an error message to fix groups when mirroring. This process works for plumbing and appliance families, why doesn't it work for casework families?
21 ANTWORTEN 21
Nachricht 2 von 22
syman2000
als Antwort auf: Ed_Cormier
Is the casework hosted on wall? If yes, it will impact the family. It will work if the family is set to non-hosted or the host wall is in the group.
Nachricht 3 von 22
Ed_Cormier
als Antwort auf: syman2000
The family is a base cabinet family which is floor hosted.
Nachricht 4 von 22
syman2000
If the floor is not inside the group, this is where you will see fix group message. Group is very picky. Often you have better success with non-hosted object within groups.
Nachricht 5 von 22
Ed_Cormier
The problem is as follows:
Work Plane-Based option enabled with labels inserted on work plane = Error
Work Plane-Based option enabled without labels inserted on work plane = No error
Work Plane-Based option off with labels inserted on work plane = No error
The confusing thing is that the problem is isolated to casework families. Plumbing and Specialty families setup the exact same way works just fine. I was hoping to avoid having to recreate all our casework families as plane based families.
Nachricht 6 von 22
syman2000
Can you provide sample group with the casework? I like to test and see if there are other way to edit the family without destroying the group.
Nachricht 7 von 22
Ed_Cormier
Attached is the Revit File with the Group in question. We get the error message while trying to mirror the group.
Nachricht 8 von 22
What is the purpose of checking Workplane in the casework families?  Are you going to place some upside down, or vertically, or on a slope?
Nachricht 9 von 22
Ed_Cormier
als Antwort auf: ToanDN
With the type of projects we do, we often have varying floor construction. When copying unit groups up to a level with a different floor type, we often see the families hosted to the original floor stay at that level...hence getting the message that identical instances are in the same place. Plane-Based families avoids this issue.
Nachricht 10 von 22
Mirror?  You can't even place an Instance of the Group, much less Mirror it.
Nachricht 11 von 22
Ed_Cormier
als Antwort auf: barthbradley
For troubleshooting, I've deleted all the casework from the group and then work with trying to place a single cabinet.
Nachricht 12 von 22
Why not just fix the Group and then make a two Groups - one a mirror of the other?
Nachricht 13 von 22
Ed_Cormier
Because of Client changes occurring often. We don't want have to make changes twice.
Nachricht 14 von 22
Ed_Cormier
We have a manual solution that uses multi-category tags keyed to type comments. So, with that being said, we've got to move on, unless there's an actual solution/ workaround.
Nachricht 15 von 22
Changes?  Are you even able to place an Instance of this Group? The darn thing is blowing up on me.  Seems to me that would be the priority.   That is, getting one to work right first, rather than figuring out how to best handle future possible changes to the Group/configuration.
Nachricht 16 von 22
Ed_Cormier
As I've stated, we need to move on. Thanks for your efforts. On another note, if you still want to work on it, I've attached the same file with all the casework removed from the group. This will not blowup on you. You can then try to add one of the cabinets with the labels and see what our issues are.
Nachricht 17 von 22
syman2000
I manage to look at what is wrong. I would check off these in the cabinet families.
Also you have constraints built into the group. This will cause it to break.
Nachricht 18 von 22
Ed_Cormier
I know about this solution. This is stated in message 5 in this chain. By turning the feature off, we're forced to host them to the floor and run into issues when copying them up to a level with a different floor type.
Nachricht 19 von 22
syman2000
This is a tradeoff. If you want it to mirror properly, then that workplane need to turn off unless it is hosted on something and that something is part of the group. Right now that workplane casework is host to nothing. When you mirror, Revit doesn't know what that casework host when it mirror and it force you to create new group.
Nachricht 20 von 22
Ed_Cormier
That's not correct, because without the label everything works. It's only when the label is nested into the casework family that Revit has the issue.
