I am able to move fixed windows with the aligned dimensions but not on the casement windows. What should I do?
Whenever I place a fixed window and I use the aligned dimension tool to move it to its correct position it works. But when I use the same method for a casement window it doesn't work and have to use the move command, and when I do this the aligned dimension gives an error and it deletes itself. Might it be a recent issue from revit 2019? Because I just download it and I didn't had this problem with previous versions.
You got me scratching my head here. It's not clear to me what you are describing. Just post the file.
