Cant see Walls -Plan view (columns are visible ) lost ..
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
jkp123
730 Aufrufe, 14 Antworten
Hello there ,
i tried everything i can from material to view range to surfing the internet for hours.
those walls wont be seen in my plan view ("קומת קרקע") but are seen in 3d view
note that the columns are visible
adding the .rvt here,
any help will appreciate
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: jkp123
What walls? There are none.
Nachricht 3 von 15
dferreira-blackwell
no walls in 3d brother.
Nachricht 4 von 15
jkp123
als Antwort auf: dferreira-blackwell
how can it be ?
i check again ... look , i see those walls in 3d...
i double checked , i downloaded the file i uploaded ...
see screenshot
Nachricht 5 von 15
dferreira-blackwell
nothinghere brother
Annotation 2019-07-25 194224.png.
Nachricht 6 von 15
Contact Sofistik.
Nachricht 7 von 15
jkp123
i dont know ... maybe this walls are currupted or something ... i still see them
look same view like you (but for some reason i cant select all elements in the view)
Nachricht 8 von 15
Here they are.
They are non-structural walls so they do not show on your structural plans.  Change the views to Coordination or check Structural box for the walls
Nachricht 9 von 15
dferreira-blackwell
Nachricht 10 von 15
als Antwort auf: ToanDN
Alright @ToanDN , I give up. You get big Brownie Button. Care to share?
Nachricht 11 von 15
jkp123
yes!!!
TY man this is it!
Edit :
well it works in Floor plan , but when i change to structural plan it doesnt work .. i still cant see them even
with the structural checkbox.
Nachricht 12 von 15
What is the view name?
Fix your view range.
Nachricht 13 von 15
I can find then and copy them to new project, but I can't see them in OPs Project.  I must be f*cking losing it!
Nachricht 14 von 15
als Antwort auf: barthbradley
FOUND THEM!!!
@ToanDN: did you just copy the OPs picture?  Funny.  You had me going.
@jkp123: I toggled the wall's "Structural" parameter on and off, and Voila! they appeared.
Nachricht 15 von 15
Don't know about the OP, but you get a solution credit from me.  I'm embarrassed.
