I'm trying to show the rooms in a plan view, But I cant work out how to do it. I've already googled this and there are a lot of different answers, but none have solved it for me.
If I try to create a new room is doesn't like it because there are already rooms created. But I cant select those rooms to do anything with them.
Can someone take a look at the attached file and see if they can work out why
Josh
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Check the section. you will see that the room is situated underneath your floor.
Good way is to create a schedule. Then you can notice that the volume was very small (less than 0.1 m3). It also allows to use highlight in view
Louis
Please mention Revit version, especially when uploading Revit files.
@Anonymous
Select the floor element >>> On the properties palette Un-check Room Bounding
Hi @L.Maas
Thanks for your input. I'm not too sure why the flooring was hovering, but I have now resolved this. This then showed the room colours, but not the tags strangely. I deleted the rooms, created them again and all is working fine with the correct volume
Thanks for your help
