I'm not trying to rotate a crop view in Revit 2022 without success. The project north is set, but the problem persists. Do you have any suggestion? I do think it is something related to worksets and collaborative work, but so far I can't figure it out.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
View Orientation (Project North or True North) has nothing to with it. If you want to rotate the Crop Boundary of the View, turn Crop on, select it and rotate it using the Rotate tool. Alternatively, you can do the same thing by assigning a rotated Scope Box to the View.
Not solved, I posted a video so you can see that I'm doing everything as usual.
Untick Copy when you rotate the crop region.
By the way, there is a scope box aligned with the view. You can set the view to use it.
Looks like you are doing it correctly. I don't know what gives. Can you do the same thing in a Duplicate View?
Good eye, @ToanDN.
@isabelle.ietka: did you see @ToanDN's revised post? That's a solution if ever I did see one.
Thanks, it was a silly mistake (working too many hours
). About the scope box, I have it any way, but first I need to align one of my views to make my S.B. orthogonal to my grids (at least that's how I do it), that one was done just by feeling.
