Cant position linked models correctly
4 ANTWORTEN 4
Nachricht 1 von 5
AidanHawkins
191 Aufrufe, 4 Antworten
Hi there, I had two linked models completed
When I stupidly changed the name of both the files
Then revit couldnt reload the links and the model positions ended up changing
I tried to match them up as best as possible but it didnt work...
And now my rooms and wall are all over the place..
What is the best practice for trying to get them back into the correct position?
Many thanks
Regards
Aidan Hawkins
4 ANTWORTEN 4
Nachricht 2 von 5
rxi.gg
als Antwort auf: AidanHawkins
"Manage > Manage Links > Reload From" didn't work?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 5
AidanHawkins
als Antwort auf: rxi.gg
I changed the file names and file location.. and then they didn't match up after
Nachricht 4 von 5
Reload From then point to the renamed files. It should work. Or just rename them back based on the old names you see in Manage links dialog.
Nachricht 5 von 5
From your description, "Reload From" sounds like the best approach here, but another approach would be to use Specify Coordinates at Point tool in the new/replacement RVT before Linking it into Parent via Shared Coordinates Positioning.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-M...
