I have a split level floor plan. While I can place electrical symbols on one level, I get the "circle with a diagonal line" when I try to place the symbols on the upper level (650mm higher).
These are standard Revit electrical socket, light switch symbols.
Anyone know how to get around this?
Thanks.
Paul
Gelöst! Gehe zur Lösung
Gelöst von D20128727. Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
check your electrical socket family sill height or post it here so we can check? thanks
Thanks very much.
The mounting height was set to 300mm which was fine for the lower level but too low for the +650mm level.
