Cant get stairs to connect 2nd floor
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
BBV90
688 Aufrufe, 15 Antworten
Hello everyone,
Trying to model a spiral stairs with but theres a gap between my second floor and the stairs. The levels are on the file. Image attached. What do I have to arrange to adjust the height of the stair so it connects to the second floor ? Need 36 steps with min 170 mm risers
15 ANTWORTEN 15
Nachricht 2 von 16
Yien_Chao
als Antwort auf: BBV90
i think the problem is from the profile... try to make another one.
Nachricht 3 von 16
BBV90
need to have 36 steps risers to be min of 170 max to 180. It still didnt work
Nachricht 4 von 16
There is nothing wrong with stairs.
If you don't want the end Riser, then edit Stair and deselect "End with Riser".
Nachricht 5 von 16
BBV90
als Antwort auf: barthbradley
It is not touching the second floor. and I need 36 steps with min 170 mm - 180 max riser
Nachricht 6 von 16
BBV90
now it is touching but risers are below min. How can I adjust that
Nachricht 7 von 16
I understand what you are saying, but your stairs are absolutely correct. If you want to "End with Tread" then you need an extra Tread.
Nachricht 8 von 16
Do you want Revit to calculate Riser Height, or do you want to calculate Riser Height?
Nachricht 9 von 16
BBV90
I just need to adjust the height of riser to be min 170 manually, is there a away for that
Nachricht 10 von 16
BBV90
 guess i want to calculate Riser Height
Nachricht 11 von 16
It is.  Obviously, you are not happy. What would make you happy?
Nachricht 12 von 16
BBV90
I just need to adjust the height of riser to be min 170 manually, is there a away for that.Im confuse sorry if there's miscommunication
Nachricht 13 von 16
Reduce the number of Risers then.
...this is what you want; right?
...you can't have your cake and eat it too.  36 Risers won't work if you want to maintain a Riser Height of around 170.
Nachricht 14 von 16
Nothing is wrong with your stair. It reaches the level but the top tread isn't there because the run is End with riser.
Normally the floor will be at the top but if you want the top tread to level with the floor then untick End with riser and add grip stretch the top dot of the run to add one more step.  Or sketch a top landing if you don't like the support to extend farther.
Nachricht 15 von 16
BBV90
als Antwort auf: ToanDN
thank you
Nachricht 16 von 16
BBV90
thank you
