Cant get out of group edit mode-more buggy software
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
CarlMaxey3179
4272 Aufrufe, 4 Antworten
Revit 2024 stays in group edit mode and there appears to be no way to exit except quit the application.  Cant save changes.
4 ANTWORTEN 4
Nachricht 2 von 5
mhiserZFHXS
als Antwort auf: CarlMaxey3179
Can you provide more details? Is the save/cancel window not popping up? Or are you clicking that and nothing is happening? Something else?
Nachricht 3 von 5
jay_colcombe
Can you confirm the The Finish and Cancel buttons are missing from the Top Right area of the View when in Edit Group or in Edit Assembly mode in Revit:
If it is an offscreen issue, then keyboard shortcuts can be used to return to normal editing mode:
  • FG – Will finish and save the group
  • CG – Will cancel the group creation modification.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 4 von 5
CarlMaxey3179
als Antwort auf: jay_colcombe
Yes the buttons disappear from screen.  Your solution works, thanks.  Hope Adesk fixes this.
Nachricht 5 von 5
I know this post is a few months old. I just had the same issue pop up. I actually had to double-click into the edit group, and Revit did not register that I was editing a group at all. No commands worked; double checked the shortcut manager. I was able to bring back the editor add/remove buttons by trying to sync. The sync failed due to being in editor mode but fixed the bug so I was able to get out.
