Cant find the navisworks exporter in revit 2016
12 ANTWORTEN 12
Nachricht 1 von 13
995 Aufrufe, 12 Antworten
I downloaded the plug in, installed  it with no errors, restarted computer, and still don't see the tool in my ribbon under add ins. A consultant of mine has Revit 2016 and his export function is located in his Revit home menu under the "R". Help please.
12 ANTWORTEN 12
Nachricht 2 von 13
kmfuhrman
als Antwort auf: Anonymous
Mine is located in the External Tools flyout on the Add-Ins tab, as well as an Export option on the Application menu.
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
Nachricht 3 von 13
als Antwort auf: kmfuhrman
That tab does not appear on my Add-ins ribbon.
Nachricht 4 von 13
kmfuhrman
Are the Exporters showing in your Windows Start menu? I would try to download and install again. Sounds like something just went awry in the install process.
Nachricht 5 von 13
Ill give that a try and see what happens. Thanks.
Nachricht 6 von 13
Still no luck. I have no clue what could be happening.
Nachricht 7 von 13
Alfredo_Medina
Do you have this?
Nachricht 8 von 13
als Antwort auf: Alfredo_Medina
Nope, that's the problem. I even "installed" from the app store still no luck.
Nachricht 9 von 13
kmfuhrman
Strange...usually if you download and save to your local machine, it works better than running it from the website. Do you have administrator privileges, or does running it as an administrator make a difference?
Nachricht 10 von 13
RDAOU
@Anonymous
Is your REVIT 2016 up to date? Can u check and provide build number or verify it against the list provided by AUTODESK on THIS LINK
if if it is not uptodate...do consider to do that and then recheck if your plug in works
Nachricht 11 von 13
arild.hoydal
als Antwort auf: RDAOU
I see this problem hasn't been marked with a solution yet, I experience the exact same thing. I have installed the separate Navisworks Exporter (Autodesk_Navisworks_Exporters_2016_Multilingual_Win_32_64bit_r2_dlm.sfx), and have the lates 2016 build (16.0.1161.0). No NWC-option in Export, nor any External Tools under Add-ins.
Nachricht 12 von 13
arild.hoydal
als Antwort auf: arild.hoydal
Finally!
I uninstalled all the exporters, restarted the computer, and reinstalled the Exporter. Now I just installed the 64bit Exporter. Not sure if this was the trick, it's possible I had Revit open when installing the Exporter initially, which might have caused the trouble. No warning to shut down Revit was given though...
Nachricht 13 von 13
hi @Anonymous,
please have a look at my post in the below link this should help.
https://forums.autodesk.com/t5/revit-collaboration-forum/install-revit-and-then-navisworks/m-p/6607580#U6607580
Jebakumar
