I just downloaded revit 2024 and I cant seem to locate PFC beams in the families. I went to US>Structural Framing>Steel, but its not there. Any help?
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Download the content library from this link below and install and restart Revit.
Here is the link: https://up.autodesk.com/2023/RVT/F1815827-A467-3271-A4D5-4738D8BFA997/RVTCPENU.exe
If this not solved the issue than revert back.
I think you need the library for Revit 2024, which you can find here: https://up1.autodesk.com/2024/RVT/717B9D0C-9DA3-3C49-BF5B-5D55DAB8247A/RVTCPENU.exe
If you do not want to download the whole package, you can download from here (Attached the families)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
