Hi everyone,
I have a stair that doesn't seem to be connected to the other stairs below but when I go to edit it, it still affects all the levels. Does anyone know how I can edit it without it changing the levels below? Thanks
Gelöst! Gehe zur Lösung
Gelöst von parkside125. Gehe zur Lösung
I ended up fixing it without affecting other levels. One thing I'm now unsure about is why the riser annotation is calculated my steps as 23 when it should be 22. Any help would be greatly appreciated. Thanks
Why affects other levels when editing? Probably is a multi-story stair. In previous versions of Revit the multi-story stair must be equal in all levels. May be this case.
Step quantities: check your runs. They're probably ending in a step instead of ending in a riser.
Rodrigo Bezerra
If it's a Multi-Story, then you need to TAB-Select the Stair "copy" and UNPIN it , in order to manipulate it independently of the other "copies".
Modify a Multistory Stair | Revit | Autodesk Knowledge Network
