Cant delete introductory text instance in family editor
13 ANTWORTEN 13
Nachricht 1 von 14
oliverberlin
579 Aufrufe, 13 Antworten
Hello fellow Revit Users,
I'm starting out in Revit and I need your help.
Starting a new family file, I have an introductory text placed on my canvas. But I cant delete it.
Thanks for reading my message,
best wishes,
Oliver
13 ANTWORTEN 13
Nachricht 2 von 14
mhiserZFHXS
als Antwort auf: oliverberlin
The delete button on your keyboard doesn't work?
Nachricht 3 von 14
Is it a profile family template? Don't worry about it.
Nachricht 4 von 14
fotaki3737
als Antwort auf: mhiserZFHXS
No it does not. All the usual ways of deleting do not work. The fact that the option delete is grayed out, after right clicking the element, tells me it has something to do with the settings in revit. I think the text field is protected from being deleted by revit. But why?
Nachricht 5 von 14
curtisridenour
can you move it?
Nachricht 6 von 14
fotaki3737
als Antwort auf: curtisridenour
Yes I can move it, even edit it.
Nachricht 7 von 14
fotaki3737
als Antwort auf: barthbradley
I do not know what its called in the englisch version, but it is the default template of the templates, where no assumptions are made. Yes I have read that you cant delete some instances in many templates.
But this feels very strange, because the note explicitly tells me to delete it before loading the family in a project.
Nachricht 8 von 14
als Antwort auf: fotaki3737
...use a different template if you don't want the text note. Still, why do you want to delete it? If it is a Profile Template for a specific type of Profile, use a Generic Profile Template and change the Profile Usage under the Properties.
Nachricht 9 von 14
curtisridenour
is it the Generic Annotation template?
Nachricht 10 von 14
It's an Annotation Template?
Nachricht 11 von 14
Post the rft and the rfa here.
Nachricht 12 von 14
syman2000
If you use generic annotation family template and switch it to the other family type category, does that work?
Nachricht 13 von 14
fotaki3737
Ok, I do unterstand. As I said im just starting out. I thought i'm overlooking something simple.
If this is normal and not a problem at all, I will just continue to learn the basics. I just got confused by the message, which tells me to delete it.
But Ive opened different templates and several of them contained instances which cant be deleted. Like annotations for example. So I'll read more into the basics, before I bother you guys with this issue.
Thank you very much for your answers!
Best wishes,
Oliver
Nachricht 14 von 14
you are right to question it. You should be able to delete that text note. Did @syman2000's suggestion work?
