Cant customize Print settings on Windows with student version of Revit 2018
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
410 Aufrufe, 2 Antworten
I have the education version of Revit for architecture. Its 2018. When attempting to print, I am unable to select the "select" button in the "print range" box to select multiple sheets. I am also unable to select the "setup" button in the "settings" box. I have tried using different printers (including PDF), and have also tried from multiple project files. Please help.
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Do not set Microsoft Print to PDF as Windows default printer. Use a different one and restart Revit.
Nachricht 3 von 3
als Antwort auf: ToanDN
Installed Cute PDF and its good to go! Thanks!
