Cant create sweep
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
jnoordzij
3992 Aufrufe, 6 Antworten
Cant create sweep
experiencing a bit of a problem here. Trying to create a sweep out of a profile and path with dimensions as shown below. In the end, an error is given. Why am i not allowed to make this sweep?
What should i do?
(EDIT: image 1 is path in top view, image 2 is profile in right view)
(EDIT: in the end i need something like bottom image (top view). This was made with an extrusion from top view but i need the detailed profile.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: jnoordzij
The sweep profile is too big for the path. It cannot make 3 segments on one side and 2 on the other. Create 2 smaller sweeps and join. Or an extrusion cut by a void.
Nachricht 3 von 7
It could be that in your profile there are overlaping lines.
See attached file.  This should be accurate.
Nachricht 4 von 7
jnoordzij
als Antwort auf: ToanDN
That sucks. But thanks.
Nachricht 5 von 7
Sorry I miss understood the geometry.
It is possible to make with an extrusion and a void.
Nachricht 6 von 7
hello bro i have same problem cannot create sweep whats a solution
Nachricht 7 von 7
als Antwort auf: Anonymous
Please send file and maybe someone can help provide a potential solution.
