Hello all,
Is there any way to copy-paste a model in place element form one project to another ? I get the error ' Some elements were not copied.
Can't Copy to Clipboard because of relationships between Elements '
Thank you in advance !
Edit the In-Place Model Component and Group all the elements together. Then -- while still in Editing Mode -- select the Group Name in the Project Browser, Right-Click on it and press "Save Group" to save the Group to an RFA. Now you can load this Family (RFA) into any Project and any time.
Finally I found all the elements related to this model-in place and I copied-pasted all together. But I will try also your option.
Have you tried the copy/monitor tool? A very skilled BIM manager just suggested to me for a similar issue.
Copy-monitoring is not so much related to the question at hand, which is simply about copying elements from one project to another. You can link it into the project though, either by saving it as group or tab-select the linked element and copy/paste-in-place ie...
