I am using Revits doors from its librabry. To give an example some of the doors i am using are called:
1. DR SINGLE STEEL FRAME 820
2. DR SINGLE STEEL FRAME 920
I need to change the materials for import into Lumion. I can change the door panels material but not the door frame material. There is an option to change both in the EDIT Type options.
When i change the door frame material it says it has changed but doesnt do anything?
Am i missing something?
Gelöst! Gehe zur Lösung
I am not familiar with those particular door. (Content of libraries may vary with versions and which country library).
You should edit the family and check how those elements receive there material.
Otherwise upload the family so we can have a look. Which Revit version are yo using and which country library do yo have installed/used?
Louis
Please mention Revit version, especially when uploading Revit files.
Hey
Im using revit 2018, Im from australia and using Aus content librabry.
How do i upload the family?
Its ok i have sorted it.
It works if i go into the family and change it.
The parameters are broken or bugged on the edit type menu
thanks
By the sound of it, the Door Frame geometry's "Material" Parameter is not associated with the "Frame Material" Parameter in the Family. I'm betting you fixed by assigning a Material from the Library to the geometry's "Material" Parameter. If so, I would go back into the Family and associate that "Material" Parameter to the "Frame Material" Parameter in host. That way it will be editable in the Project.
FWIW
I am having a similar problem but I am not sure how to fix it how you describe. Could you please send screenshots showing the different steps?
Basically I have an exterior sliding door that will not display any materials. I have tried editing several parts to it/the family but I feel like I must still not be connecting the right things. Thanks in advance!
