Cant change in place component material
1 ANTWORT 1
Nachricht 1 von 2
tigerdroney
132 Aufrufe, 1 Antwort
I modelled some planters as in place components using extrusions. I want to change the materials of these but in the properties tab it isn't like normal and there's no options to change material. I then tried to select a planter< edit in place< modify < family types and add material as a parameter and then assign. But then when I click ok the whole component just disappears! Ive attached a screenshot of when I click on my component.
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: tigerdroney
@tigerdroney
After u edit the in place component...
  1. select the planter geometry
  2. and from the properties palette, click on the button next to the material
  3. associate its material to a parameter or to the parameter u already created
