Haven't been able to get this to work:
It's just a little wing wall that I want to show correctly joined to the slab for detailing purposes.
When you attach the wall to the floor, choose Base instead of Top from the Option bar.
Wouldn't the proper way be more like this - with masonry wall atop a level drop ledge or a level stem wall or a level footing? Basically, wall has a negative Base Offset to meet the top of whatever level thing is supporting it.
Otherwise, the wall won't be level and plumb. Just saying.
