cant able to delete the spiral staircase
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
1078 Aufrufe, 15 Antworten
Hello all,
I am trying to  delete the spiral staircase but its not happening.  Its not visible in Plan, Elevation and Section, only visible in 3D view. I am wondering if anyone could let me solve this issue.
Thanks in advance.
15 ANTWORTEN 15
Nachricht 2 von 16
Avaris.
als Antwort auf: Anonymous
You only selected the run? Deselect. Try to tab and select the stair as a whole and press delete. Left bottom you see what you select in case you click.
Nachricht 3 von 16
Corsten.Au
Hi
Check the "Workset" make it editable..
I can see you are working in Non Editable Workset, and Revit is not allowing you
to make any changes cause you don't own the workset...
Best luck
Corsten
Building Designer
Nachricht 4 von 16
als Antwort auf: Corsten.Au
It's strange. All the worksets are active and editable. still, the staircase had grayed out and I couldn't able to delete them.
Nachricht 5 von 16
ennujozlagam
hello, reset temporary hide/isolate and then delete or check your phasing (show all..etc) and see if helps. thanks
Nachricht 6 von 16
als Antwort auf: ennujozlagam
Hii,
I tried to reset, nothing helps.
Thanks.
Nachricht 7 von 16
ennujozlagam
hello, is there anyway you can share the file so we can check. thanks
Nachricht 8 von 16
ennujozlagam
how about phasing have you check it? thanks
Nachricht 9 von 16
Hii,
I sent you a personal message.
Thanks a lot.
Nachricht 10 von 16
ennujozlagam
ok, i'll take a look. thanks
Nachricht 11 von 16
ennujozlagam
hello, your file is a worksharing file, check with you, are you working alone on the file or with your colleague? ( i'm thinking that this file, you received from other consultant without detaching it). thanks
Nachricht 12 von 16
ennujozlagam
hello, because if you working with worksharing file you need to save first then synchronize with central and get a grant from other user before you can delete. thanks
Nachricht 13 von 16
ennujozlagam
hello, ok go to project browser > right click select type properties > untick tread your spiral staircase will be deleted. thanks
Nachricht 14 von 16
Hii,
If I untick the icon, I am losing the entire staircase (above and below). I just want to delete the particular floor staircase.
Is there any other way to solve the issue?
Thanks a lot.
Nachricht 15 von 16
ennujozlagam
hello, you need to create a new spiral staircase because if you pick your existing spiral staircase there is a error message warnings, that is the reason why you having this problem. thanks
Nachricht 16 von 16
It works perfectly. I appreciate your help.
Thanks a lot...
