Cannot view 1st flr from 2nd flr
4 ANTWORTEN 4
Nachricht 1 von 5
336 Aufrufe, 4 Antworten
I've been using Revit for a few years off and on. I use 2017 student version to keep updated. I drew a 1st floor and when i went to 2nd floor there was nothing there. I set underlay to 1st floor and nothing shows. I set view range to level below nothing happened either. So, i'm not sure what's going on. I don't recall this problem on 2014 Revit,the last program i drew a house on. Can anyone help me?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Hey there.
Can you share with us your project file? The Underlay works normally at Revit 17.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Nachricht 3 von 5
...in 2017, the Underlay also has  View Range settings. Check those.
Nachricht 4 von 5
als Antwort auf: barthbradley
Thanks ive tried everything . I just copied work into a new project it seems to work correctly perhaps i was in a different template im not used to. Anyway its a continuous learning endeavor thanks for the help.
Nachricht 5 von 5
Thanks i copied it into a new project and it is behaving normal. Im not sure what i did but on i go thanks for the offer of help.
