Cannot Update Topography Material
3 REPLIES 3
prateek.mehtaWJ72N
304 Views, 3 Replies
My Revit file has some topography overrides. There are overrides for the topography type as well.
Now, when I change the material in the topography it does not update in the 3D view.
Is there anything wrong with the override settings? When I completely turn off the overrides for topography it hides the topography completely which I don't want. Please suggest what override should be used.
Is there another possible reason why the topography material is not updating even after selecting and picking material from the materials section as seen in the figure - topography materials.
Would appreciate any response. Thanks!
Labels (1)
3 REPLIES 3
Hi, topography doesn't allow surface patterns only cut patterns here
Gustavo Ubriaco Contreras
If it's only the material in realistic view, are you selecting the material for the topography from here?
Sorry I've just seen your images they are really clear, I got confused with the second one on the suface patterns
what happens when you create a new 3d view?
Forma Design Contest
