Cannot Unpin or Delete Revit Element With "Corrupt Internal Join Data"
37 ANTWORTEN 37
GELÖST
Nachricht 1 von 38
4125 Aufrufe, 37 Antworten
Hi, I am having probably my worst day in Revit so far. I was changing some of the floor levels on a project, and everything was correcting just fine. When I got to one specific floor level, I get error "Element's internal join data is corrupt". I was able to isolate the element by ID number, but I am unable to do anything but select it. I cannot unpin, I cannot move, I cannot Delete... ANY HELP would be greatly appreciated, as there is a forehead shaped dent in my desk at this point..
37 ANTWORTEN 37
Nachricht 2 von 38
jair_gh
als Antwort auf: Anonymous
Quick workaround, try to link it to a new file and then bind it, just to see what happens
Nachricht 3 von 38
Audit?
Nachricht 4 von 38
Kimtaurus
There are a few options.
- Open the file with Audit.
- Can you select the wall and change it's type?
- Aside from moving, can you grab a wall end and maybe change it's length, so it's no longer joined to any other walls? And then maybe delete the wall.
- Linking the model and then binding it could work, but you could lose some data (if I'm not mistaken: plan views and possible annotations).
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 5 von 38
als Antwort auf: ToanDN
I cannot do anything to the element (a currtain wall). I cannot make any changes to walls that it is joined to either. I cannot change it's type. I cannot unpin, I cannot unjoin, I cannot isolate anything within the element. Any and all action I have tried to take is always met with the same corrupt join data error.
I am not sure what an audit involves? Is that a possible solution that will preserve my work so far?
Nachricht 6 von 38
Kimtaurus
The audit is done when opening the file, you won't loose anything in your file. It just checks all the elements for data corruption. Unfortunatly it doens't prompt any messages on what Revit has fixed.
To audit a file, go to Open -> Select File -> at the bottom left corner of the open-window is a checkbox for Audit -> check Audit -> Open file.
Nachricht 7 von 38
Kimtaurus
Do you have a version of the model where this problem doesn't exist yet? (A back-up file maybe).
You could open both versions in the same Revit session, and copy the newer elements (without the corrupted curtain wall ofcourse) to the old file.
This way you don't lose too much work.
Nachricht 8 von 38
als Antwort auf: Kimtaurus
After opening the project under AUDIT, it seemed to only take a bit longer to open than normal. I assumed this may be revit fixing the issue, but upon opening, and re-trying the same level change, all the same errors relating to the element's join data being corrupt are still preventing me from doing anything about the issue.
My firm is at a very critical point with this project, and we really cannot afford to lose anything or re-do work at this point. Is there any other possible solution that doesn't invlove going to old versions, or nuking things from space?
Nachricht 9 von 38
1. Are you auditing before changing the level?  How about do it after?
2. If the above still fails and since you already noted the ID of the element, then inspect/ fix/ delete it BEFORE changing the level.
Nachricht 10 von 38
I tried auditing the file before opening. It did not work. It is impossible for me to try auditing "after" changing the floor level, because my whole problem is NOT being able to change it at all, becuase every time i go to move it it gives me the same error message, and I can't do anything about it other than cancel the move. The error is "element's internal join data corrupt"... it will not let me do ANYTHING with the element other than select it, and the element is preventing me from moving the floor level... I'm at a boiling point because we are currently trying to meet a deadline with information, and I'm unable to make the model accurate... Pretty much the worst problem you can have at this time.
Nachricht 11 von 38
Why don't you delete it before changing the level and rebuild it afterward?
Nachricht 12 von 38
Kimtaurus
@ToanDN That's exactly his problem, he can't do anything to the element, not even delete it.
My best guess is still to go to an older version (without the corruption) and copy all the new elements from the latest version to this old file.
Nachricht 13 von 38
Hmm I thought it only happens AFTER he moved the level.  Does it always happen no matter what?
Nachricht 14 von 38
Yes, this happens anytime I attempt to drop down the floor level that the corrupt element is on. I cannot actually complete the move, delete the element, unpin the element, or move or alter anything it is joined to.
Nachricht 15 von 38
cbcarch
Does the curtainwall have an Edited Profile? Or, is it Attached at top/bottom to a roof or floor? I have found these can cause the error you are getting.
If so, can you Rest Profile or Detach?
I know you said you could not do anything to it--does it show the "puzzle piece" icon when you select it? If so, click it and select Make Element Editable or Make Workset Editable. See if a certain user has it Owned or Borrowed--look under Collaborate>Worksets.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 16 von 38
Viveka_CD
Hi @Anonymous
Sorry to hear that you are facing issues.
Is it possible that you share the Revit model and a journal to investigate further? Let me know and I can share a private folder link.
We'll be happy to log a support case and work with you towards a resolution.
Nachricht 17 von 38
als Antwort auf: Viveka_CD
Yes Viveka, I have tried everything, and still cannot get anywhere with this. I've tried all of the above suggestions multiple times and nothing has worked. Please send me the link where I may share the project file.
Nachricht 18 von 38
Viveka_CD
Hi @Anonymous
I'm sorry to hear that the issue persists.
I've shared a private upload link with you - please let me know if you have trouble accessing this folder.
Let me know if you have any questions.
Nachricht 19 von 38
Viveka_CD
Hi @Anonymous
Just checking back if you were able to upload the file?
Let me know if you have trouble accessing the folder? This was sent to your email on file.
Nachricht 20 von 38
Viveka_CD
Hi @Anonymous
Thanks for sharing your journal and Revit model.  We require a few more files to investigate further.
I have sent you a collector utility to extract more required files.
The issue is in progress. We haven't got a result yet, so I will have to kindly ask you to wait a little more.
Meanwhile, please update Revit 2018 with the latest version, your journal shows that you are the first customer ship with build number 20170223_1515. Please run the updates from the Autodesk Desktop App.
Let me know if this resolves the issue, but we will continue testing your file.
Thank you very much for your patience.
