I have a problem that suddenly developed in my building model, where I can no longer select the handrail supports. I was working on a railing family, as a handrail with supports, and it was working fine - I could select the supports, unpin them, and move them as needed. Now, all of a sudden, seemingly out of nowhere, I cannot select the supports. In any railing family that uses handrail supports.
Is there a setting somewhere that I inadvertently switched off? I've never seen this happen before. Usually unpinning handrail supports works just fine.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Check and see if this is unchecked
If that didn't work, check and see if the object is placed under design option
I use that setting constantly, and had overlooked it while working on the railing. Thank you. mpp
