Cannot select guide grid
bengalik
bengalik
Revit 2022 Newbie.
I add a guide grid to an existing project sheet.  I then am not able to select the grid in order to manipulate it.
I can select the title block (which is custom) and can activate/deactivate the view.
If I create a new project and add the guide grid to a sheet, I am able to select and edit the guide grid.
Did I somehow corrupt my existing project?
Maybe it's pinned and a selection restriction is active?
...if that isn't it, then try creating a new one via "Create New" .
bengalik
Its not pinned and I removed all of the selection restrictions.
What I do see is if I use a selection window for the entire sheet and then Filter to select just the guide grid, the guide grid is now selected and I can edit it.  I can live with that but wish I knew why it behaves this way.
thanks,
RSomppi
Are you selecting the edge of it?
Do you see the Grid Guide shape handles?
It might be underneath another element, such as a View Boundary.  Use TAB-Select to cycle through overlapping elements.
bengalik
That was it.  It was underneath the View Boundary.
Thank you for your help.
