Cannot Select Dormer Cutout
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
BugFinder
1553 Aufrufe, 3 Antworten
Has anyone had trouble selecting a dormer cutout in a roof before.
No matter what I do, I cannot select the cutout - I can tab until the key breaks but I cannot select it.
I can select it if I delete parts of the model; for instance the dormer walls or even totally unrelated features to the dormer or roof structure.  For some reason then it'll let me select the hole but this kind of defeats the object when you have to delete parts of your work in order to select other parts!!
Is this a known bug or am I going about it the wrong way?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: BugFinder
Window-Select everything, and find it through the Filter dialog box?
...silly question I got to ask: are you sure the Dormer Opening is hosted to the main roof and not to the Dormer Roof. I've done that before and got weird behavior.
Nachricht 3 von 4
Did you look at the status bar when you TAB?  I don't have any issue selecting the opening cut.
Nonetheless, using filters to weed out the rest will work if all else fail.
Nachricht 4 von 4
BugFinder
als Antwort auf: ToanDN
Yep, looked at the status bar and nothing flashed up when tabbing through.  Very strange!!
I have it now through a filter.  Strange thing is that the filter identified 2 cutouts (I must have somehow created two) but tabbing through couldn't even get one of them...
