cannot see my hatch in exterior 3d view
4 ANTWORTEN 4
Nachricht 1 von 5
frankie.love
291 Aufrufe, 4 Antworten
I am trying to add a new finish to my exterior walls on my condo complex. This is a file that was previously provided by a teacher of mine for my college course. Once I add the hatch pattern to my exterior walls I can't see them in 3D, and I need an elevation of each (NESW) face. I am able to see the pattern show up when I am in my floor plan. Also, I just want the exterior face of my exterior walls to be hatched, not the inside. I've been stuck for days, so any advice would be greatly appreciated!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: frankie.love
Nachricht 3 von 5
Try flip the walls inside out by select them and press space bar.
Nachricht 4 von 5
How are you adding the hatch?  Are you Painting the Wall with a Material that has a Surface Pattern or is the Material with Surface Pattern defined in the Wall Assembly?
Nachricht 5 von 5
lim.wendy
Hi @frankie.love
Welcome to the Revit forum.
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
