I need to show a small amount of HVAC piping in my model. I was able to draw it in plan view but a message popped-up saying that I won't be able to see it. I can see it in 3D view but I need to show it in my floor plan drawings. How would I be able to make the HVAC system visible in them?
Just adjust your view range in the view you can't see it. Also, make sure that category is turned on in the view.
Thank you for posting this on the forum,
I would agree, check the view range as you most likely placed the objects above the view range - making it unable to be displayed.
Alternatively it might have been unchecked in the visibility graphics, if you need some help checking let me know,
Best Regards,
I am not sure but because it is HVAC systems maybe you need to view them in ceiling plan view instead of the regular plan view
