Hi, I have just done a render with Interior : Sun & Artificial but I cannot save the render to the normal Render tab in the Project Browser. I can only export it as an external image. Any idea why.
Also, what is the best setting to get both the lights inside the building lighting up what is inside and also a good external render at the same time. I need to be able to have a good external finish and also see in through the large windows so the brewery equipment can be seen.
Below is my building but I didn't have any lights inside when I did it so its a bit dark and you can only just make out the equipment in the bottom left window, need to make them brighter if it possible. I did think about doing a separate render with the lights on and then cutting the windows out and pasting them into this image?
Hey, I had the same problem, and I simply solved it by making sure my sky settings were not translucent. The button will not be greyed out if you have the sky set as a color, or with any number of clouds.
