When running an "audit" returns currupt
This means that your project is corrupt and can not be repaired easily.
If you are on subscription you can create a support ticket and ask Autodesk to have a look at it.
Otherwise it will be using a backup file.
Louis
Please mention Revit version, especially when uploading Revit files.
@Anonymous wrote:When running an "audit" returns currupt
If you contact your reseller, they may be able to expedite the process if this is a work stop issue. I've seen files cleaned up and returned the same day.
I am experiencing that we get a corrupted file while Revit 2017 tries to Audit an Central File.
Luis Santos
archi systems as
I am using Revit 2017.2.2 and having this error message when auditing a central file. I would like Autodesk Support to check my file. How / to who should I send this .rvt document?
