Hi Everyone!
I've just started working on a new project (the project is about 2 years old) and I've been getting a pop up saying cannot sync, cannot reconcile differences with central model. Apparently this has been happening for the last year or so.
The project is a 40 story residential tower block in Stage 5 so making a new model isn't really an option.
I've done everything I can think of to get rid of it, I've created a new file (detached and saved as) , audited and purged, check all the links and stripped most of the CAD files out.
The file is also over 900 MB.. I've tried shrinking it by stripping views, options and unneeded geometry from families and the model, replacing it with detailed lines but its barely made a dent.
All of the 302 apartments were made in the tower project as GROUPS-yes I know revit hates groups. (not the way i would of done it, i would of made them as individual projects because there are 30 repeating types and linked them in to the tower model to keep it light, is that the correct way?)
When the file (attempts) to saves now it creates a new file FILE_NAME(data conflict from ******* with *******).rvt
ANY suggestions at all would be helpful as we are loosing work at the end of each day at the moment!
Thank you!
WOW impressive to be limping along for so long with 900Mb file!
Here's a few suggestions that you may want to consider to increase performance.
The Synchronisation issue maybe caused by the large file size not caching the data on save and running out of memory. So you really need to get this file size down.
I have a motto, take the time to make the time... time taken to improve performance will save you time in the long run.
Hope this helps
