Cannot open the Revit software - student version
Message 1 of 12
I can´t open the revit software anymore. All the time there is an error massage. The second user on my computer is able to open the software. The cancellation is so fast, I don´t even know the reason of the fault.
I don´t know what to do. There is no technical support for students. How is this possible?
Please help me.
Replies (11)
Message 2 of 12
RobDraw
It sounds like a problem with your profile. Your instructor (or whoever set-up your profile) should be able to assist with this.
Rob
Message 3 of 12
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley Happy
I'm sorry to hear that you are facing issues.
Which version of Revit are you using?
Can you try a repair of Revit and let me know if this helps?
Message 4 of 12
Hello you two,
I already tried to repair the software. The problem is still there. I also installed the hole software again. But the problem isn´t solved either.
I use the 2018.3 version of revit. So I also tried the update. And I installed the software by myself, so there is no one to help me.
I really don´t know what to do.
Message 5 of 12
RobDraw
Once again, I think this is a profile issue. There should be someone available that sets up the user profiles. Maybe the software needs to be installed as an administrator.
Rob
Message 6 of 12
Viveka_CD
Hi @Anonymous
Can you repost on the installation forum or contact support for activating your product?
Message 7 of 12
Hello Viveka,
in germany there is no technical support for student license. So I posted my problem on the other forum and I hope someone can help me.
And I am the admin of my computer. And the other user not, so the second user don´t have more rights.
Alida
Message 8 of 12
RobDraw
If one user works and the other (admin) doesn't, what is different about the profiles?
What happens if you create a new user profile?
Rob
Message 9 of 12
Viveka_CD
Hi @Anonymous
Can you try creating a new profile and see if it resolves the issue?
Please follow these steps below:
Here's how to create another account on your PC
  • Note: To help keep your personal data and info more secure, we recommend adding a password when creating a local account.
  • On Windows 10 Home and Windows 10 Professional editions:
    • Select the Start  button, then select Settings  > Accounts  > Family & other people > Add someone else to this PC
    • Enter a user name, password, password hint, and then select Next. Note: If you’re using Windows 10, version 1803, you can add security questions—instead of a hint—to your local account to help you reset your password in case you forget it. Check your version of Windows 10
  • On Windows 10 Enterprise edition:
    • Select the Start  button, then select Settings  > Accounts  > Other people > Add someone else to this PC.
    • At the bottom of the page, select I don’t have this person’s sign-in information, and at the bottom of the next page, select Add a user without a Microsoft account.
    • Enter a user name, password, password hint, and then select NextNote: If you’re using Windows 10, version 1803, you can add security questions—instead of a hint—to your local account to help you reset your password in case you forget it. Check your version of Windows 10
  • To make the new account an administrator account, select Start  > Settings  > Account  > Family & other people (or Other people, if you're using Windows 10 Enterprise), and select Change account type. Under Account type, select Administrator > OK. Restart your machine and sign in with the new administrator account.
Looking forward to hearing from you.
Message 10 of 12
Actually, this was also my idea and I think this is my only option. And this is working.
Thanks for your help.
Message 11 of 12
Viveka_CD
@Anonymous Good to hear. Thanks for letting us know!
Please let us know if you have additional questions!
Happy to help Smiley Happy
Message 12 of 12
RobDraw
You're welcome.
Rob
