hello,
i have file that created in revit 16, when i try to make few command in the model i get a fatal error and when i try to audit the file i get an error that to many elements are missing.
i also tried to open the file in revit 17,18,19 and still cannot audit the file.
i have the latest version of revit.
dose anyone had that problem?
Hi @tzahia
Is this error specific to a particular model?
Have you installed the latest updates for your Revit versions from the desktop app?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
