Hi Everyone,
I am having an issue to modify an aligned dimension. First, select the dimension, then I click on the dimension box to modify it. Next appears a Dimension Text dialogue box, which doesn't allow you to modify the actual number. I have done it in the past and was able to change the number, but now this Dimension Text dialogue box appears. There doesn't seem to be anything I can change in properties.
What am missing??
Any suggestions would be appreciated
Not entirely sure what you mean, do you want to display a different number then its actual value?
Try adding an invisible symbol at the end of your value.
I figured this out. You need to select the element, not the dimension, in oder to change the size of the element.
Thanks.
