Cannot Locate OOTB Families
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
trevorpan
2249 Aufrufe, 8 Antworten
I'm in a trial trying out Revit LT.
Cannot seem to access families. Is this a subscription restriction?
Thank you,
Trevor
Trevor Pan
http://www.trevorpan.com
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: trevorpan
No it is not a subscription restriction it could not be installed properly. try to install again but you need to switch off all your anti virus program and firewall before installation and see if this helps. Thanks
Nachricht 3 von 9
RobDraw
I'm not sure if antivirus and firewall is going to make any difference if you've successfully installed it once. There is a separate download for the content but first you should verify that you are looking in the right place and that Revit is also looking in the correct location.
Also, see this from Autodesk:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Rob
Nachricht 4 von 9
trevorpan
als Antwort auf: RobDraw
Hi Rob,
Accidentally accepted as solution.
I've gone through those steps. Uninstalled, redownloaded and it still does this?
Bizarre.
Trevor
Trevor Pan
Nachricht 5 von 9
RobDraw
Did you catch the part that says it's a separate download?
Rob
Nachricht 6 von 9
trevorpan
Check this out. It says it's installed, but I get the same screen when I go to insert family....
Trevor Pan
Nachricht 7 von 9
chrisplyler
By default, family files are typically stored in a location like the following:
  • C:\ProgramData\Autodesk\<product> <release>\Libraries
Navigate to that location and see if it contains Revit LT family folders and files.
Nachricht 8 von 9
trevorpan
als Antwort auf: chrisplyler
Hi Chris,
Cannot seem to find that.
Tried this post to. No luck..
https://forums.autodesk.com/t5/revit-architecture-forum/installation-of-revit-2017-content-libraries...
Trevor Pan
Nachricht 9 von 9
chrisplyler
I suggest you do a Windows search for the term "Libraries" and see what shows up.
