Whenever I try to load in certain doors, nothing happens. I can load in some doors, windows, tvs, etc. just not specific doors. I do not get an error message either, just nothing happens. I'm using Revit 2019.
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
Do you mean you can't place them after loading?
There are just a few families in a blank rvt file, loading a family means that it becomes available in the project environment. For example, if you do a specific project you might want to load also specific families but after that, you also need to place them. CM is the shortcut for placing a loadable family.
No, I click to load them in and hit open and then go to the architecture tab and select door and in the properties panel when I click on the drop down to select a different door, what I tried to load in is not there
Can you show me a screenshot how you load them?
I go Insert> Load Family> Click on Door-Curtain- Wall- Double- Glass> Open. Then the load family window closes and there is no door when I go to Architecture> Door> Click on the drop down arrow by "single flush" and the new door is not there
Ah, that is because that specific door is only for in curtain walls. So you can unpin a panel in your curtain wall and replace it by this one. You will see it appears in the drop-down when replacing.
The door double flush panel would appear in the drop-down you are showing me.
