Cannot join roofs at an oblique angle.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
565 Aufrufe, 4 Antworten
How do I join a roof that is at an oblique angle? The roof join command fails when I attempt this. See photo
Beschriftungen (1)
  • Roof
4 ANTWORTEN 4
Nachricht 2 von 5
martijn_pater
als Antwort auf: Anonymous
Overlap them and use vertical opening cut on it (architecture tab).
Nachricht 3 von 5
mauricio_mssf
Can you send the file with only the roofs for us to analyze?
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 4 von 5
als Antwort auf: mauricio_mssf
I found out what it was. The oblique roof did not like that the preliminary roof was attached to walls. Once I detached this the roofs joined.
Nachricht 5 von 5
constantin.stroescu
you don't need two roofs for this...You can do it only with one Roof by Footprint...
Constantin Stroescu
