Cannot hide hidden lines by elements
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
788 Aufrufe, 8 Antworten
Hi All,
I'm creating a section but somehow that section show the wall of the other room as hidden line. I have tried "remove hidden line by elements" but failed as I think it is a wall instead of an element?...
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: Anonymous
use invisible lines to hide. thanks
Nachricht 3 von 9
als Antwort auf: ennujozlagam
May I know what is supposed to happen after I select invisible lines?
Modify>Linework>Line Style: Selected the line that I don't want to show > ?
Nachricht 4 von 9
Change the view's discipline to Architectural or Coordination and Hidden line to By Dicipline.
Nachricht 5 von 9
als Antwort auf: ToanDN
I can turned off those lines but as well as other hidden lines.
Please let me clarify that I only want to show the elements of Room 1 but somehow the wall line in Room 2 has showed up as hidden which it should not be showing up. thanks.
Nachricht 6 von 9
ennujozlagam
it will be hidden in that view.
Nachricht 7 von 9
Those invisible lines can still be seen on the sheet layout but it didn't show up after I plotted. Kind of bother me that those invisible lines are visible on the computer but I guess I have to live with it :Gesicht_mit_Zunge: Thanks!
Nachricht 8 von 9
Those invisible lines can still be seen on the sheet layout but it didn't show up after I plotted. Kind of bother me that those invisible lines are not invisible on the computer lol but I guess I have to live with it :Gesicht_mit_Zunge: Thanks!
Nachricht 9 von 9
ennujozlagam
the lines are still there just that make them invisible in that view. thanks
