the 2 wall are aligned to the same plane, they made from the same material and ofcourse joined. it's just 2 different families.
How can i get rid of the line between them?
the elevation look terible, loaded with lines.
Gelöst! Gehe zur Lösung
Gelöst von danezeq. Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
In the Modify tab, click on the Linework tool. Select Invisible Line and click on the lines that you don't want to see. They will disappear.
Thank you.
This methood works well per view. is there any way to cancel those line on geometry? (meaning i wont see them on all views)
Some of the lines are going invisible and some are staying no matter how many times i click over them.
any ideas?
In that case, I would use the Join command to join both walls.
yep that helps sometimes
but i found the main problem in the specific example: DESGIN OPTIONS! some of the elements i clicked on are belong to a design option.
if anyone have this problem in the future....
