Cannot find furtinure, do I have to install that separately?
15 ANTWORTEN 15
Nachricht 1 von 16
971 Aufrufe, 15 Antworten
I followed all the steps of the site below. However, I do not have any furniture to place in my drawings. Do I have to install these furniture libraries separately?
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
15 ANTWORTEN 15
Nachricht 2 von 16
aRcHiTeCt.JM
als Antwort auf: Anonymous
... if you are connected to internet when installing REVIT the content libraries will be installed
... if you have a fire wall or no connection
... then you have to install those manually
... which version of REVIT do you installed?
... did you download from the site you are showing the specific libraries for your REVIT version?
... did you follow all steps?
... after installation is important to do this:
Follow these steps to set the correct paths to the content within Revit:
  1. Open Revit.
  2. Go to the Revit Options -> File Locations.
  3. Click the Green + sign, and enter the desired default project template. Project templates are located by default in the following folder:
    C:\ProgramData\Autodesk\RVT ####\Templates\US Imperial\
  4. Set the default path for family template files to the following:
    C:\ProgramData\Autodesk\RVT ####\Family Templates\English_I
  5. Click the Places button.
  6. Set the Library Path for the Imperial Library (or just Library) to the following:
    C:\ProgramData\Autodesk\RVT ####\Libraries\US Imperial
  7. Set the Library Path for the Imperial Detail Library (or just Detail Library) to the following:
    C:\ProgramData\Autodesk\RVT ####\Libraries\US Imperial\Detail Items
  8. Click OK, then click OK again.
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 16
Not normally.  Can you access any loadable families? Not being able to access one particular folder in the library, is very strange.
Nachricht 4 von 16
@Anonymous: Is it possible you accidentally dragged the "Furniture" folder into another Library folder?  Maybe it's in the "Fire Protection" or "Furniture Systems" folder?
Just a thought.
Nachricht 5 von 16
als Antwort auf: aRcHiTeCt.JM
Thank you for your response.
I tried these steps and followed the video about it.
So, far, I do not have any furniture.
I made also the library folders as shown in the video (what seems odd because a library of furniture should already been in place).
Do you know what could be the matter?
Nachricht 6 von 16
als Antwort auf: barthbradley
There is no furniture inside one of these. C:\ProgramData\Autodesk\RVT 2019 It is so odd, I really would expect that their would be furniture. I followed all the steps of the link provided in my first message. Including the step of the video wherein I have to make the folder 'US Metric' and 'Detail Items.'
Nachricht 7 von 16
aRcHiTeCt.JM
.... unistall REVIT
.... reboot pc
... install REVIT with internet so that way you can get all libraries  this will be automatic
... done
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 8 von 16
Unfortunately I have tried that before. Hmmmmm… I have to find another solution I guess.
Nachricht 9 von 16
I now tried to install it through the Autodesk Desktop App, unfortunately now everything is set to feet and inches. That is a pity.
Nachricht 10 von 16
aRcHiTeCt.JM
... try to do the same proccess that you did for that
... then try at the begining find the metric libraries
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 11 von 16
Thank you for your response, I will try that.
To the developers of Revit: 'I do not want to do that, Revit should just work after installment to my opinion.'
Nachricht 12 von 16
I tried it and I do not have the Areabook Library, Buildingbook Library and Roombook Library in the US Metric version. So, I cannot change the Library Path.
Do you know where to install these libraries?
Thanks in advance for your response.
Nachricht 13 von 16
Those Libraries are installed by add-ins.  Don't worry about them.
Your screenshot above shows you have a Libraries Folder. Have you searched in that folder for "Furniture"?
Nachricht 14 von 16
I found the furniture, finally..
By the way, why I should not worry about the other libraries/add-ins?
Nachricht 15 von 16
Where was it???
No, don't worry about the others.  They will get installed with the Add-in.
...Was I right?  Accidentally dragged into another folder?
Nachricht 16 von 16
During installation you are given the choice of Imperial vs Metric...you can also make sure you are starting with correct template in the file locations under options.
