Cannot extend layer(s) of the highlighted vertically compound wall.
20 ANTWORTEN 20
GELÖST
Nachricht 1 von 21
18503 Aufrufe, 20 Antworten
Hey all,
I started a project in revit and i have some problems with attaching walls to my floors.
First i made all floors and afterwards i created my walls.
The problem is when i want to change the size of the floors, so that the floors are behind the outer layer of the wall, i get the error message : Cannot extend layer(s) of the highlighted vertically compound wall.
What can i do to fix this?
I unlocked some layers of the wall but it only seems to work for the first 2 floors.
Can anybody help me maybe?
Thanks in advance.
20 ANTWORTEN 20
Nachricht 2 von 21
tamas_badics
als Antwort auf: Anonymous
This is apparently a bug. I will file a bug report on it. It is caused by your walls both being attached to the floor and their type having unlocked layers. In the meantime you can either detach your walls or lock all their layers. I suggest you detach the walls since your model has very flat structures so the attachment does not by you all that much. Sorry for the inconvenience. Tamas
Tamás Badics
Software Architect, Revit
Nachricht 3 von 21
GHASEM_ARIYANI
hi
Floor must extend to the exterior Core Boundary No extend  to edge finishing wall layers.
then Select wall and First attach upper wall and Second Attach to upper Floor.
http://forums.autodesk.com/t5/revit-architecture/unlock-the-both-directions-wall-layers/td-p/5286509
You can also use the Join Geometry tool .
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 4 von 21
als Antwort auf: tamas_badics
How is this bug progressing? It's still happening in R2019.2
Nachricht 5 von 21
Agreed!!!  I am still getting this, and if they call that a "feature" I'll scream!
Nachricht 6 von 21
Its a bug. The way i fixed it is by detaching the walls from the floor, moving the floor to a different level then moving it back to the original level, then attach the wall again.
Nachricht 7 von 21
Yeah... that doesn't work...
Nachricht 8 von 21
rickybZ9FS8
Hello Tomas,
Was this ever fixed?  I am having the same issue with Revit 2021.  Cannot have the wall attach to anything if I want to adjust the height of finishes.
Nachricht 9 von 21
ross57R29
Go into the wall editor, in Structure click edit. At the bottom of the "Edit Assembly" window click preview, make sure the view tab is set to "Section: Modify Type". Click modify and lock all boundaries that have been unlocked. Then change the thickness of the wall.
Nachricht 10 von 21
tbryanm
DITTO 22.1!!
Autodesk is not interested in making their software better. They're too busy pushing the next version onto the street.
Nachricht 11 von 21
noahCHT4G
als Antwort auf: tbryanm
I cannot believe that this is still a problem. I cannot believe that we all pay a small fortune for this software every year and they refuse to fix this. There are so many similar examples of knucklehead glitches in the software that have persisted for yeeeeears without a fix, and they cost us serious hours. I'm looking for a non-autodesk alternative. I'm considering just going all in on Rhino. Anyone have a suggestion that's more BIM-y?
Nachricht 12 von 21
mhiserZFHXS
Obviously Revit has issues, but how exactly is "pushing the next version onto the street" not providing updates to the software? That's what the new versions are.
Nachricht 13 von 21
als Antwort auf: noahCHT4G
Nachricht 14 von 21
tbryanm
als Antwort auf: mhiserZFHXS
Because there are bugs, or just plain bad software design, that delay end user productivity going back to at least Revit 2009, and STILL exist with each new version. Making the software better is not the same as releasing versions with cute bells and whistles.
Nachricht 15 von 21
gosha_tomasikYJU4Y
I am in Revit 2024... Still having the SAME issue. What is even the point of posting here and hoping for a solution when clearly this issue has not been addressed. So disappointing.
Nachricht 16 von 21
als Antwort auf: gosha_tomasikYJU4Y
@gosha_tomasikYJU4Y wrote:
I am in Revit 2024... Still having the SAME issue. What is even the point?
The point what?
Nachricht 17 von 21
The first answer addresses the issue.  If you want to attach a wall then do not unlock layers.  You can duplicate the wall type if you want some walls to attach automatically, and some others with layers manually stretched.
Nachricht 18 von 21
gosha_tomasikYJU4Y
My wall layers are locked. I am unable to attach my wall to the roof. I have copied it, deleted it, pasted it. Did not work. I redrew it from scratch. Didn't work. Other walls that are the same wall assembly have no issue attaching. So, that first answer did not address the issue for me. Thanks.
Nachricht 19 von 21
Copy paste the wall and the roof to a new file and share it.
Nachricht 20 von 21
g_vakili
i am in revit 2025 and still same issue
