CANNOT EXPORT RENDERED WALKTHROUGH
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
2509 Aufrufe, 10 Antworten
I'm trying to export a RENDERED walkthrough to no avail. The render stalls out and never goes past 0% completion....I've successfully exported a small segment of the entire walkthrough about two months ago but now, its not working at all.
I've tried every possible solution and tip that's out there: clearing temp folder, exporting to img, making sure hardware acceleration is on, chopping up the walkthrough (0% complete after leaving overnight for 10 frames @12 frames per sec), etc.
The walkthough does export when I switch to any mode besides rendered.
Anyone got a clue? Is the amount of trees / cars / incidents I have in the model? From personal experience, coplanar surfaces really bogs down the rendering. Could that be the issue?
Thanks!
10 ANTWORTEN 10
Nachricht 2 von 11
dzanta
als Antwort auf: Anonymous
have you tried using another workstation?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 11
Viveka_CD
Hi @Anonymous
What format are you exporting to -  AVI or image file?
Please attach a screenshot of your settings.
Nachricht 4 von 11
als Antwort auf: Viveka_CD
Nachricht 5 von 11
For those using a Nvidia Quadro M4000 graphics card, setting CUDA - GPUs to 'None' seems to work.
I'm only testing out this setting over 10 frames. I'll post an update tomorrow morning after testing it over 300 frames.
Nachricht 6 von 11
Viveka_CD
Hi @Anonymous
Just checking back on this issue, were you able to export successfully?
  • Which version of Revit are you using? Use this tool to find recommended system hardware or graphics hardware and drivers.
  • See the article HERE for Creating a rendered walkthrough
  • Check out this interesting tutorial on Lynda HERE which talks about rendering tips.
  • An alternative for doing the full 300 frames: maybe on computer one, you could do frames 1 through 50 and set it to rendering and let it generate those images. And then on computer two, you could set this to 49 through 100. Then use post-processing software to stitch these together.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Nachricht 7 von 11
@Viveka_CD
Yes! I was able to export a rendered walkthrough by adjusting the Nvidia setting. The export was only 10 frames. I'll post an update tomorrow after exporting the entire animation.
Thanks!
Nachricht 8 von 11
Viveka_CD
Hi @Anonymous
That sounds good!
Looking forward to your update.Smiley (fröhlich)
Nachricht 9 von 11
@Viveka_CD
Unfortunately I'm running into another problem...there seems to never be enough RAM for rendering a walkthrough.
The rendering stopped about 1/4 of the way through (78/300 frames @ 15fps, 1600x1200 resolution, AVI). For this workstation, It needed more than the 16GB of RAM that was available.
I also noticed that as the rendering progressed, the amount of RAM it used also increased (initial baseline of RAM usage was 11GB).
I'm now rendering the walkthrough on another workstation with only 12GB of RAM. The rendering's been going for 4 hours but only managed to render 28 frames. However it looks like the RAM usage is hovering around 10GB.
Nachricht 10 von 11
Viveka_CD
Hi @Anonymous
Sorry to hear that you are facing issues with the export.That is a lotttt of RAMSmiley (überrascht)
I was able to look up some solutions for you!Smiley (fröhlich)
To improve speed and performance when generating walkthrough renderings, you can try the following: (since your updates are all in place, I suggest you look at points 3,4 and 5)
1. Keep your Revit version up-to-date
Apply the most current updates or service packs for Revit. Download from your Autodesk Account.  Can also check here for service packs: Autodesk Download Finder
2. Simplify the walkthroughs and settings
The speed is going to be dependent on the number of frames/second, the Visual Style being used, etc.  Try different settings here. Also doing shorter walkthroughs and then splicing the videos is a consideration
3. Beef up the hardware
Using SSDs can help performance. Increasing RAM is often a good idea. Here’s a recommended AU class/whitepaper on the topic of hardware: IT21325: A Hardware Wonk's Guide to Specifying the Best 3D and BIM Workstations—2016 Edition
4. Consider using 3DS Max in your workflow
Here are some AU classes on that:
AB5204: Rendering and Animation for Building Design with 3ds Max
AV9943-L: Mastering 3ds Max Basics, from Beginner to Final Render
5. Consider using Autodesk LIVE
If you haven’t discovered Autodesk LIVE yet, it’s certainly worth investigating.  Not only can it do walkthroughs fast, it allows for dynamic walkthroughs and explorations rather than a pre-scripted, pre-pathed walkthroughs.  Here’s additional information on LIVE.
Autodesk LIVE product page
DV21709: Bring Your Work to Life with the Live Design Workflow
Autodesk LIVE Help Home
Autodesk Community LIVE Forum
Autodesk LIVE Viewer (Free Viewer)
Autodesk LIVE AKN Search
Regarding wanting to render walkthroughs in the cloud, that suggestion has been posted as a Revit Idea.  You can vote it up here: A360 Cloud Rendering Walkthrough for Revit
Thank you.
Nachricht 11 von 11
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
