Cannot export a lookup table.
1 ANTWORT 1
Nachricht 1 von 2
551 Aufrufe, 1 Antwort
I created a family with many different parameters. I would like to export those parameters to a lookup table. Unfortunately when I go to lookup table Manager, the "Export" Option is disabled. I can only Import some lookup table, but I don't have any yet. How to solve this problem?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Lookup tables are primarily for pipes and conduits and other "variable size" components of that nature. If you have not assigned your family to a type able to use lookup tables, you won't be able to export them. Perhaps try a type catalog instead? This wont give you quite the same functionality, but it will allow to select from a number of (still parametric) options when inserting your family.
